may be a bad coil. messing up the ignition.
it sounds to be something in the ignition.
our deere did something similar. would roll and roll but no start. pulled plug. had fire, but seemed erratic. it would start on occassion because of it being a twin. but would'nt stay running.
just my advice. not sure what mower you got. but most brands that run a kohler, use same parts. maybe you got a buddy that has one as well. swap out the parts and see if it helps yours and hurts his.
save from buyin something you dont need.
