Killswitch does not work!!!!!!!!
975 Views 3 Replies 4 Participants Last post by  dagger350
I hooked up a pro armor killswitch on my 05 450r and it will not shut engine off, runs as if it wasn't even hooked up.
1 - 4 of 4 Posts
I hooked up a pro armor killswitch on my 05 450r and it will not shut engine off, runs as if it wasn't even hooked up.[/b]
it only needs to be connected to the black wire with white and pink stripes. Trace it from the switch on the handlebars. Then find a good place to ground it. make sure to remove the paint from where you ground it on the frame.
Be sure to scroll down to read instructions for "-=Killswitch info with the key=-" if you still have the key assembly attached. I just rewired my pro armor killswitch using these directions and works great now.
1 - 4 of 4 Posts
