Hey fellas I have a issue I'm hoping you can help me with. One day out of the blue my 2009 450R refused to start, weird I thought because it ran flawless when I parked it.......... so naturally I go to the common sense things like did i remember to put fuel in the dam thing and yes i had. Then moved on to spark and no I didn't have. I looked over everything I could think of and just couldn't find the problem. The next day I went out and just out of frustration started flipping the kill switch back and forth at fast as I could while cranking it(essentially just going from kill to kill as fast as my fingers would move) now it's not always fast as in I will do this for 30 seconds and it will pop a couple times then start (if I'm quick enough to stop in the middle when I can hear it just about fire. Once running there is no issue with performance. My question is has anyone had this issue ? Can I just disconnect one of the wires and be sure it is or isn't just a bad kill switch ? I have absolutely no idea why but I have a gut feeling this is deeper and 2 reasons for that is #1 I took the switch apart and cleaned it really well and same problem. #2 if I'm coasting down the canyon in neutral with the motor off I can simply turn the key on, put it in gear and fires intantly (push start or roll start) I wonder if something is just loose or dirty but I feel like I have looked over everything I could think of. Any input would be appreciated. Sorry for the long post. I just wanted to be thorough because it's hard to help if you dont have as much information as possible. Thanks guys, and gals.
