1 - 3 of 3 Posts
So is this a common problem on the kicker bikes? I’ve seen two now like this. I think back to the days of my dirt bikes and never had this issue, ever. Not even on either of my 2 CR500’s
Automotive tire Motor vehicle Vehicle brake Alloy wheel Automotive lighting
If you are applying the throttle while kicking or your carb isn’t tuned properly then yes it’s more common. Seen it many times.
05 TRX450R
Why, because of kickback? I would think maybe it's flexing on the inside like that bearing is junk or the shaft is bent. Which a bent shaft could happen from kickbacks.
1 - 3 of 3 Posts
