1 - 11 of 11 Posts
Who all has converted from an electrick to kick start? Are you glad you did? Where did you get the parts for and how much? Thanks
Who all has converted from an electrick to kick start? Are you glad you did? Where did you get the parts for and how much? Thanks[/b]
i converted over but i kept the electric also. i am to cheao to buy the piece you need if u take the starter off. i got all the internal sprockets and shafts from ebay for 75. u just have to make sure it is for an 04-05 or 06-08 the one shaft that comes out of the case is different. i got the kicker for 35. alls i had to do is buy a new gasket. by far the best mod that i have made
Discussion Starter #3
So I must get a kit for an 06 then correct? You need to find me a deal like that! If you have any links that would be great! I havent found a kit for less than 380. What piece do you need to remove the starter? Thanks
yes u will need a kit for an 06 then. if you can find a 04-05 kit. u can go to honda a buy the shaft that the kick start attaches to. i think it is 60 dollars. the 06 is like an inch longer. if u take the electic start off you need some electrical piece. i was told it was 70 dollars from baldwin motorsports. i will look for some deals for ya.
Bobby Racers edge sells the kit for around 300 I believe... Think it includes everything you need..
Discussion Starter #7
Would you happen to have a number? I can't find it, Thanks!
Discussion Starter #8
Will I need anything else beside the kit? Does anyone make something to cover the starter motor hole? Thanks a lot
Would you happen to have a number? I can't find it, Thanks![/b]
1 520 631 0797
Discussion Starter #10
thanks. I called them and they don't offer a kit. All they have is part numbers.
thanks. I called them and they don't offer a kit. All they have is part numbers.[/b]
If you add up the price of all the parts separately, Would it total around 300$?
Their should be a few topics with the part numbers floating around.
1 - 11 of 11 Posts
