1 - 2 of 2 Posts
So I have an 04 . Has hmf s/o . Modified air box lid , foam filter, 190 main 52 pilot. Not sure of the sea level I live in Scranton Pennsylvania. Everything is stock. Needle position is in third slot. A/f screw two turns out. My issue is it’s running lean. Backfiring only decel. I just want it to run properly. So just changed main jet from 180 to 190. PLEASE help me
If it's doing it on deceleration quit messing with the main jet
Either your pilot is clogged or you have an exhaust leak or the af screw is missing or has a bad O-ring because a 52 is to big.
1 - 2 of 2 Posts
