whats ur main jet? and did u change it when u changed intakes? im guessing no?
u should be in the 162 range on the main
I have a 2005 with the ESR and Stage HC2 and I run a 190 main. I started with the dyno jet but then just went and bought some bigger mains. I think the kit come with up to a 180 main.whats ur main jet? and did u change it when u changed intakes? im guessing no?
u should be in the 162 range on the main[/b]
^^^what he said....i had a dynojet on my '05 and i didn't like it too well......try their 180 first, it may be too small.......there is a comparison thread on here somewhere b/t dynojet, keihin, and mikuni somewheres...........but try ur jet kit first and do a plug check it may work out^^^I have a 2005 with the ESR and Stage HC2 and I run a 190 main. I started with the dyno jet but then just went and bought some bigger mains. I think the kit come with up to a 180 main.whats ur main jet? and did u change it when u changed intakes? im guessing no?
w/e the hrc kit came with???? idk for sure if they send one of those in the kit, but if they don't, i left mine stock and it works great!cool, will do that, thanks alot...any other input is helpful....thanks alot guys...u think my leak is too big? what does everyone usually run?[/b]
