21 - 30 of 30 Posts
Don't forget the needle, sounds like you compensating a too low needle with a too large pilot.
While I'm here,
2008 TRX450ER XC oriented
Stock carb, HC2 cam, midrange oriented high velocity porting, stock valves and springs, green wire (switched), 2,5inch perf core muffler with 1,75 in HRC header, uni filter cut lid, 11,7:1
5k : 30whp 6k to 10k:40+whp [email protected]
Pilot : 42
Idle screw 1 turn hot summer, 1,5 fall (hard to start cold, easier hot after a stall)
Needle : HRC needle 1st clip (low needle, leaner setting)
Main : 155, lean at low RPM, 13:1 AFR from 7 to 10K RPM
Leak jet : 35 No bogs but a longer AP squirt would cure a 15:1 lean out peak, so more volume from AP would be golden.
Haven't swapped air jets to richen the low RPM, there is only a pilot air jet, but the prolem seem on the main circuit, may need a differrent needle jet (pereforated emulsion tube) and a Main air jet to flatten the afr.
I may go efi next year
trx 450 2007
Alright I got 15 different Jetting set-ups for all different years.
I have them in order by year, so you can find your year and similar mods and hopefully get a better feel of where your jetting should be... I know some more of you gave me your info but without knowing some key components, I didn't want to use it.
Anyway if you want to add anymore info, just add it to the other thread in the lounge and I will update this post.
http://www.trx450r.org/forum/92-lounge/186162-lets-put-end-jetting-questions.html
This is not intended to give you the exact jetting for your machine but rather a good starting point and some assistance if you are completely lost.
Another good read on the topic and something you should definitely look over before doing any work on your carb is...
http://www.trx450r.org/forum/93-engine/175649-jetting-questions.html
Anyway... Here is the list that I got... and if any of this helps you out, remember to thank the guys listed above each machine for sharing their info
steve450rr
Year: 2004
Exhaust: Full Curtis Sparks
Intake: Uni Filter w/ HRC Lid
Other Mods: HC Stage 1
Elevation: Sea Level
Main Jet: 190
Pilot Jet: 48
Leak Jet: N/A
Needle/Clip Position: HRC / 3rd Groove
Fuel Screw: 2 ½ Turns out
abshire1006
Year: 2004
Exhaust: Sparks
Intake: Velocity w/ K&N Filter
Other Mods: Procomp
Main Jet: 190
Pilot Jet: 50
Leak Jet: N/A
apple61a
Year: 2004
Exhaust: Full Alba
Intake: K&N w/ Outerwears, No Lid
Other Mods: N/A
Elevation: 1000 Ft.
Main Jet: 185
Pilot Jet: 50
Leak Jet: N/A
Needle/Clip Position: Dynojet / 3rd Groove
Fuel Screw: 2 ¼ Turns out
ridinredodb
Year: 2004
Exhaust: Full HMF Ballance Pro
Intake: No Lid
Other Mods: HRC Kit, 12:1 Piston. Stainless Steel Valves
Elevation: 1000 Ft.
Main Jet: 185
Pilot Jet: 52
Leak Jet: N/A
Needle/Clip Position: HRC / HRC Recommended
Fuel Screw: Unk.
Brian Smith (I don't have a Screen Name)
Year: 2005
Exhaust: Full LRD Pro 4
Intake: Uni Filter w/ No Lid
Other Mods: HC Stage 2, CP 12:1 Piston, FCR Carb
Elevation: 1543 Ft.
Main Jet: 162
Pilot Jet: 48
Leak Jet: 55
Needle/Clip Position: HRC / Middle Groove
Fuel Screw: 1 7/8 Turns out
fedfireman
Year: 2005
Exhaust: HRC Header, Pro Circuit S/O
Intake: K&N, HRC lid, intake spacer
Other Mods: HRC Cam
Elevation: 150 Ft.
Main Jet: HRC 185
Pilot Jet: Stock
Leak Jet: N/A
Needle/Clip Position: HRC / Unk.
Fuel Screw: “Here & There”
dr_dig-it
Year: 2005
Exhaust: Cut Dasa
Intake: Dasa
Other Mods: Minor Port work, +1 Valves, Web 493/729 Cam, 14.17:1 Piston, 43.5 FCR Carb
Main Jet: 220
Pilot Jet: 45
Leak Jet: Unk.
Needle/Clip Position: Adjustable / 2nd Groove from Bottom
Fuel Screw: Unk
oneill_1952
Year: 2006
Exhaust: HMF S/O w/ HRC Header
Intake: Uni Filter w/ Lid removed
Main Jet: 165
Pilot Jet: 45
Leak Jet: Unk
Needle/Clip Position: NGPR / 3rd Groove
Fuel Screw: 1 ½ Turn out
camo_fox
Year: 2006
Exhaust: Full Dasa
Intake: K&N w/ Outerwear, No Lid
Other Mods: N/A
Elevation: 1000 Ft.
Main Jet: 165
Pilot Jet: 42
Leak Jet: Stock
Needle/Clip Position: Dynojet / 4th Clip down
Fuel Screw: 2 Turns out
kenjermain11
Year: 2007
Intake: Cut Lid
Other Mods: HRC Kit
Elevation: 850 Ft.
Main Jet: 165
Pilot Jet: 48
Leak Jet: 55
jdiner1
Year: 2007
Exhaust: Dasa Classic
Intake: Uni Filter, No Lid
Other Mods: 477 CW Big Bore, 12:1 Piston, HRC Cam
Elevation: 5,300 Ft.
Main Jet: 162
Pilot Jet: 42
Leak Jet: 55
Fuel Screw: R&D Adjustable Unknown Turns out
airmobile101
Year: 2007
Exhaust: Full Rossier
Intake: Uni Filter w/o cage, modified lid
Other Mods: 13.5:1 piston, CRF Head Gasket, 2005 Carb
Elevation: 600-800 Ft.
Main Jet: 172
Pilot Jet: 48
Leak Jet: N/A
Needle/Clip Position: Stock / Middle Groove
airmobile101
Year: 2007
Exhaust: HMF
Intake: Uni Filter w/ modified lid
Other Mods: 13.5:1 Piston, HC Stage 2, 40mm FCR
Main Jet: 165
Pilot Jet: 42
Leak Jet: 50
Needle/Clip Position: NCVQ / Middle Groove
Fuel Screw: 2 ¾ Turns out
450rquadrider
Year: 2007
Exhaust: HMF S/O
Intake: Uni Filter w/ HRC style lid
Other Mods: N/A
Elevation: 300 Ft.
Main Jet: 165
Pilot Jet: 45
Leak Jet: Unk.
Needle/Clip Position: Adjustable / 3rd Groove
alanbmx
Year: 2008
Exhaust: Dasa
Intake: K&N w/ outerwears
Other Mods: HRC Cam, HRC sub-harness
Main Jet: 168
Pilot Jet: 45
Leak Jet: 55
Needle/Clip Position: OBEL-R / 5th Groove
Fuel Screw: R&D Flex-Jet / 2 1/8 Turns Out
Burke_78
Year: 2008
Exhaust: MotoWorks Sr4 S/O w/ HRC Header
Intake: UNI Filter w/ Lid Removed
Elevation: 2400 ft
Main Jet: 162
Pilot Jet: 42
Leak Jet: 55
Fuel Screw: 1 7/8 turn out
TRX 450 2007
Exhaust: HMF full
Intake: Uni Filter w/lid off
Other Mods: N/A
Elevation: 1500 Ft.
Main Jet: 162
Pilot Jet: 42
Leak Jet: Unk.
Needle/ OEM CLIP
Fuel Screw: 3 Turns out
trx 450 2007
steve450rr
Year: 2004
Main Jet: 190
Pilot Jet: 48
Leak Jet: N/A
abshire1006
Year: 2004
Exhaust: Sparks
Other Mods: Procomp
Main Jet: 190
Pilot Jet: 50
Leak Jet: N/A
apple61a
Year: 2004
Exhaust: Full Alba
Other Mods: N/A
Elevation: 1000 Ft.
Main Jet: 185
Pilot Jet: 50
Leak Jet: N/A
ridinredodb
Year: 2004
Intake: No Lid
Elevation: 1000 Ft.
Main Jet: 185
Pilot Jet: 52
Leak Jet: N/A
Fuel Screw: Unk.
Year: 2005
Elevation: 1543 Ft.
Main Jet: 162
Pilot Jet: 48
Leak Jet: 55
fedfireman
Year: 2005
Other Mods: HRC Cam
Elevation: 150 Ft.
Main Jet: HRC 185
Pilot Jet: Stock
Leak Jet: N/A
dr_dig-it
Year: 2005
Exhaust: Cut Dasa
Intake: Dasa
Main Jet: 220
Pilot Jet: 45
Leak Jet: Unk.
Fuel Screw: Unk
oneill_1952
Year: 2006
Main Jet: 165
Pilot Jet: 45
Leak Jet: Unk
camo_fox
Year: 2006
Exhaust: Full Dasa
Other Mods: N/A
Elevation: 1000 Ft.
Main Jet: 165
Pilot Jet: 42
Leak Jet: Stock
kenjermain11
Year: 2007
Intake: Cut Lid
Other Mods: HRC Kit
Elevation: 850 Ft.
Main Jet: 165
Pilot Jet: 48
Leak Jet: 55
jdiner1
Year: 2007
Main Jet: 162
Pilot Jet: 42
Leak Jet: 55
airmobile101
Year: 2007
Main Jet: 172
Pilot Jet: 48
Leak Jet: N/A
airmobile101
Year: 2007
Exhaust: HMF
Main Jet: 165
Pilot Jet: 42
Leak Jet: 50
450rquadrider
Year: 2007
Exhaust: HMF S/O
Other Mods: N/A
Elevation: 300 Ft.
Main Jet: 165
Pilot Jet: 45
Leak Jet: Unk.
alanbmx
Year: 2008
Exhaust: Dasa
Main Jet: 168
Pilot Jet: 45
Leak Jet: 55
Burke_78
Year: 2008
Elevation: 2400 ft
Main Jet: 162
Pilot Jet: 42
Leak Jet: 55
TRX 450 2007
Exhaust: HMF full
Other Mods: N/A
Elevation: 1500 Ft.
Main Jet: 162
Pilot Jet: 42
Leak Jet: Unk.
Needle/ OEM CLIP
:smile2:
TRX 450 2006
Exhaust : Baldwin full
Intake : Fuel custom Intake, no airbox
Other mods : ported head, 42.5mm ported carburetor, HC Stg3, +1mm exhaust valves
Elevation: 400FT
Main jet : 210
Pilot Jet : 45
Leak jet : Unk
Needle : S
Fuel screw : 2.5 turns out
Did 55whp/36wtq
I have a all stock 05 trx450r was gonna put a full white brothers on it and kn filter take lid off what for jetting am I looking to start with and if I decide keep lid on for when it's wet and muddy what should I start with on that
2007 trx450er
Full rossier
Hrc kit
Uni filter with outerwears
168 main
45 pilot
55leak
R&D flex jet roughly 2 1/8 out
Acc pump- hrc recommend 1/18 in
@sea level in hot a$& Florida ....
No bog issues at all.... all go !
2006 trx450er
Exhaust: sparks full
Intake: stock without lid, k&n with outerwear
Other: 14:1 piston(stock bore), ported and polished head with kw springs, green wire mod. Hot cam stage 2.
Elv. Sea level to 2000ft.
Need jetting recommendations please
Jetting now:
Main: 175
Pilot: stock
Fuel: 2.5 turns
Leak:55
Bike has serious bog from idle to full throttle. Doesn't bog much if the rpms are high. And the clip is on the 4th slot. Sparks jet kit.
2007 trx450er
i have a 2007 trx450er that has a stock exhaust with stage 2 hot cams. when i hit the throttle 1/4 way in it has a dead spot and blogs but past that its fine. I dont know what jets to use please help!!
06 450R, stage 2 hot cam, header, sea level, K&M, cover off
just did 165 primary and 45 pilot.... , no power/starving low RPM, bat out of hell high RPM, what should the pilot jet be?, or something else?
Bought the quad, was ridin high altitude, Oregon
21 - 30 of 30 Posts
