1 - 20 of 30 Posts
Super Moderator
Alright I got 15 different Jetting set-ups for all different years.
I have them in order by year, so you can find your year and similar mods and hopefully get a better feel of where your jetting should be... I know some more of you gave me your info but without knowing some key components, I didn't want to use it.
Anyway if you want to add anymore info, just add it to the other thread in the lounge and I will update this post.
http://www.trx450r.org/forum/92-lounge/186162-lets-put-end-jetting-questions.html
This is not intended to give you the exact jetting for your machine but rather a good starting point and some assistance if you are completely lost.
Another good read on the topic and something you should definitely look over before doing any work on your carb is...
http://www.trx450r.org/forum/93-engine/175649-jetting-questions.html
Anyway... Here is the list that I got... and if any of this helps you out, remember to thank the guys listed above each machine for sharing their info
steve450rr
Year: 2004
Exhaust: Full Curtis Sparks
Intake: Uni Filter w/ HRC Lid
Other Mods: HC Stage 1
Elevation: Sea Level
Main Jet: 190
Pilot Jet: 48
Leak Jet: N/A
Needle/Clip Position: HRC / 3rd Groove
Fuel Screw: 2 ½ Turns out
abshire1006
Year: 2004
Exhaust: Sparks
Intake: Velocity w/ K&N Filter
Other Mods: Procomp
Main Jet: 190
Pilot Jet: 50
Leak Jet: N/A
apple61a
Year: 2004
Exhaust: Full Alba
Intake: K&N w/ Outerwears, No Lid
Other Mods: N/A
Elevation: 1000 Ft.
Main Jet: 185
Pilot Jet: 50
Leak Jet: N/A
Needle/Clip Position: Dynojet / 3rd Groove
Fuel Screw: 2 ¼ Turns out
ridinredodb
Year: 2004
Exhaust: Full HMF Ballance Pro
Intake: No Lid
Other Mods: HRC Kit, 12:1 Piston. Stainless Steel Valves
Elevation: 1000 Ft.
Main Jet: 185
Pilot Jet: 52
Leak Jet: N/A
Needle/Clip Position: HRC / HRC Recommended
Fuel Screw: Unk.
Brian Smith (I don't have a Screen Name)
Year: 2005
Exhaust: Full LRD Pro 4
Intake: Uni Filter w/ No Lid
Other Mods: HC Stage 2, CP 12:1 Piston, FCR Carb
Elevation: 1543 Ft.
Main Jet: 162
Pilot Jet: 48
Leak Jet: 55
Needle/Clip Position: HRC / Middle Groove
Fuel Screw: 1 7/8 Turns out
fedfireman
Year: 2005
Exhaust: HRC Header, Pro Circuit S/O
Intake: K&N, HRC lid, intake spacer
Other Mods: HRC Cam
Elevation: 150 Ft.
Main Jet: HRC 185
Pilot Jet: Stock
Leak Jet: N/A
Needle/Clip Position: HRC / Unk.
Fuel Screw: “Here & There”
dr_dig-it
Year: 2005
Exhaust: Cut Dasa
Intake: Dasa
Other Mods: Minor Port work, +1 Valves, Web 493/729 Cam, 14.17:1 Piston, 43.5 FCR Carb
Main Jet: 220
Pilot Jet: 45
Leak Jet: Unk.
Needle/Clip Position: Adjustable / 2nd Groove from Bottom
Fuel Screw: Unk
oneill_1952
Year: 2006
Exhaust: HMF S/O w/ HRC Header
Intake: Uni Filter w/ Lid removed
Main Jet: 165
Pilot Jet: 45
Leak Jet: Unk
Needle/Clip Position: NGPR / 3rd Groove
Fuel Screw: 1 ½ Turn out
camo_fox
Year: 2006
Exhaust: Full Dasa
Intake: K&N w/ Outerwear, No Lid
Other Mods: N/A
Elevation: 1000 Ft.
Main Jet: 165
Pilot Jet: 42
Leak Jet: Stock
Needle/Clip Position: Dynojet / 4th Clip down
Fuel Screw: 2 Turns out
kenjermain11
Year: 2007
Intake: Cut Lid
Other Mods: HRC Kit
Elevation: 850 Ft.
Main Jet: 165
Pilot Jet: 48
Leak Jet: 55
jdiner1
Year: 2007
Exhaust: Dasa Classic
Intake: Uni Filter, No Lid
Other Mods: 477 CW Big Bore, 12:1 Piston, HRC Cam
Elevation: 5,300 Ft.
Main Jet: 162
Pilot Jet: 42
Leak Jet: 55
Fuel Screw: R&D Adjustable Unknown Turns out
airmobile101
Year: 2007
Exhaust: Full Rossier
Intake: Uni Filter w/o cage, modified lid
Other Mods: 13.5:1 piston, CRF Head Gasket, 2005 Carb
Elevation: 600-800 Ft.
Main Jet: 172
Pilot Jet: 48
Leak Jet: N/A
Needle/Clip Position: Stock / Middle Groove
airmobile101
Year: 2007
Exhaust: HMF
Intake: Uni Filter w/ modified lid
Other Mods: 13.5:1 Piston, HC Stage 2, 40mm FCR
Main Jet: 165
Pilot Jet: 42
Leak Jet: 50
Needle/Clip Position: NCVQ / Middle Groove
Fuel Screw: 2 ¾ Turns out
450rquadrider
Year: 2007
Exhaust: HMF S/O
Intake: Uni Filter w/ HRC style lid
Other Mods: N/A
Elevation: 300 Ft.
Main Jet: 165
Pilot Jet: 45
Leak Jet: Unk.
Needle/Clip Position: Adjustable / 3rd Groove
alanbmx
Year: 2008
Exhaust: Dasa
Intake: K&N w/ outerwears
Other Mods: HRC Cam, HRC sub-harness
Main Jet: 168
Pilot Jet: 45
Leak Jet: 55
Needle/Clip Position: OBEL-R / 5th Groove
Fuel Screw: R&D Flex-Jet / 2 1/8 Turns Out
Burke_78
Year: 2008
Exhaust: MotoWorks Sr4 S/O w/ HRC Header
Intake: UNI Filter w/ Lid Removed
Elevation: 2400 ft
Main Jet: 162
Pilot Jet: 42
Leak Jet: 55
Fuel Screw: 1 7/8 turn out
Super Moderator
Discussion Starter #2
Guys if you want to add your info, go for it... just please try to follow the format and give as much information as you can to avoid confusion
Year: 2006
Exhaust: HMF Header HMF Performance Slip on.
In take: The biggest Specter Filter I could find mounted directly to the carb. No box. Outerwear pre filter
Other Mods: Hot Cam stage 2 , Stage 3 CDI and ignition. 13.75 to 1 compression.
Boisen accelerator pump.
Sea Level......Ohio
Main Jet: 180
Pilot Jet: 42
Leak Jet: 40
Needle/Clip Position: middle.
A/F screw 1/4 from bottoming out.
Accelerator pump screw backed out 1.25
450 **** Raiser
What some good info!
Got a couple questions. I have an 05 with hrc lid, stock filter, mxp full exhaust, 192 main, 52 pilot, screw 2.25 out. 13:1 wiseco but at idle, my header turns welders red. just the first 90*, but revving in neutral no backfire, but when i let off the throttle when im going down the road, it pops. not really loud, just a little. header only gets a little red when im riding, which is normal. but it shouldnt at idle. Do i need to go up to a 54 pilot, or mess with the screw? Oh and i heard i cant go off the plug very well since its water cooled.
2008 450er, sea level, K&N w/outerwear,No airbox lid, Two Bros M7 slip-on, green wire mod, completely stock motor. Oh I live in South Alabama if that matters. Thanks!
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Looking for help with a dead spot just past idle to 1/16th throttle on a "new-to-me" bike. If you want to just idle along giving just ever so little gas, it'll die. Get past that, or just past 1/16th throttle and its fine. Leak jet? Carb jets cleaned and valves freshly adjusted. If this isn't the right thread, please point me in the right direction. Tks.
2006
FMF Titanium Slip-on
UNI, HRC lid.
No green wire mod yet.
165 main
48 short pilot
Leak - Stock
1-7/8 turns out on the pilot screw.
The rest is stock.
2006
UNI, HRC lid.
165 main
48 short pilot
Leak - Stock
The rest is stock.
Green wire mod and 55 leak....
Derek_Thompson24
Year: 2004
Exhaust: Full Dasa Classic w/Quiet Core Insert
Intake: K&N w/Prefilter w/Dasa Billet Adapter, No Lid
Other Mods: N/A
Elevation: 1750 ft
Main Jet: 180
Pilot Jet: 50
Leak Jet: N/A
Needle/Clip Position: HRC Needle, 3rd Clip
Fuel Screw: 1.5 out
jetting
I have a 2004 trx 450 it revs up good but seems not want to idle very good at all, I'm sure its the carb and curious where is a good start on adjustment
stock pipe
pilot 48
main 122
screw 1 1/2 out
k & n air filter
cylinder works big bore kit
any ideas would be great I'm hoping to ride this weekend
185 main, 50 pilot. screw 2.5 turns out. Double check valves in spec as well.
Super Moderator
Discussion Starter #14
stock pipe
pilot 48
main 122
screw 1 1/2 out
k & n air filter
This thread was never intended for people to ask questions in, but as a reference to look for a build similar to yours and give you a starting point with jetting... but since you asked, I will give it a go...
Stock pipe with a big bore?... kinda pissing on the wheels of progress there.
Airbox lid still on and complete with snorkel?
Stock cam?
If so, I would go with a 50 pilot, 125 main, and 2 turns out on your fuel screw, if you don't have an Airbox lid... then go with post above.
thanks for the ideas, I'm going with a pipe and probably cam too just haven't got all the parts in yet figured I would break in the top end while I waited
So I'm trying to get my carb situation figured out, I have been messing with it the last few days with a bunch of trial and error. quad is an 08 450r stg 2 hotcams, K&N w/ lid on and header back exhaust. I just installed a 165 main and a 48 included ( I think it's the pilot jet ) from the HMF jet kit. And I turned my air fuel screw out 1 1/2 turns. It a still a little hard to start and cuts out under 1/4 throttle. Anybody have Any suggestestion I want to ride this beast asap Thanks a bunch
1 - 20 of 30 Posts
