1 - 5 of 5 Posts
What’s up group.! I have a 04 Honda trx 450r kick start. I’m having this issue with the quad. If I’m riding for about 3+hrs it’s start to spill out antifreeze. I think that is spilling from the reservoir or from under the hood. Or from the hose that connects to the radiator. My fan hardly kicks on nor my over heating light ever turn on. I check the coolant and it’s pretty full.
Should I be riding it or parked it and have it checked out.
Could it be a over heating problem
Thanks and have a bless day
And keep on riding
Sounds like it may be a bad head gasket. Usually when it’s a head gasket the quad won’t be running overly hot, the overheat light will not come on, but it will push coolant out the overflow hose coming from the reserve tank
If its head gasket bypass then you'll notice when you run it hard, not so much duration of, but how much load before bypass occurs. My 2 cents.
1 - 5 of 5 Posts
