Ok, so I just did a routine top end on my 04. Took it to the track and spent about three hours breaking it it. When I went to get on it comming out of a turn it sounded like the head gasket blew and there was a loud clanking noise which sounded like the piston smacking the valves. I went straight home and I started tearing it down.
I can't find anything wrong,
The timing was still set dead on and the cam chain was still tight. I removed the head and the top of the piston was perfectly fine. No marks from valves or any carbon build up. So I pull the cylinder and everything looks perfect. Rod bearing is fine, and the new piston is clean.
So, I start examining the head. The valves look fine, no marks on them. I hold the head upside down and I pour some solvent on the valves and theres no leaks.
I decide to put the thing back together. I kept the valve cover off and I kick it over real slow and there is still something deffinetly smacking inside. I know the vavle clearance is good.
If anyone has anything I should look for that is just flying over my head please let me know. Thanks.
