alright well i have been interested in the HRC kit and its durability, and a new thread came up in the dyno room by a member and about the hrc kit sub harness and if the extra 1k rpm is worth the extra wear and tear on the valvetrain.
anyways, the way it exactly works is, the subharness raises the RPM limiter another 1k, but also from the hrc kit manual it states,
""this modification provides a different ignition advance curve designed to complement the other components of the kit"
what exactly does this mean, sounds like you need to run higher octane gas, but the hrc kit manual still says 91 or higher. is this the case because of the more AIR and fuel that is being delivered in the cylinder?
