1 - 5 of 5 Posts
The link you posted doesn't work. FYI the org doesn't like ebay.
Sent from my SAMSUNG-SM-G891A using Tapatalk
As long as you get an HRC Kit for a 2006+ TRX450ER it will work on your 2013 TRX450ER. FYI the 2006 to 2014 TRX450ER is the Identical quad exception of the Plastic's and Head Light Change in 2007. Other why's all the Engine/Carburetor parts in the 2006 to 2014 will interchange.
The cams on the 2009 and newer are different if I'm not mistaken. Honda change the decomp setup on them. If you want to run a cam from a 2008 or earlier then you have to change the cam holder.
1 - 5 of 5 Posts
