1 - 4 of 4 Posts
how much hp do you guys think im pushing? My mods:
05 trx450r
Stock bottom end, sbss
12.8 je piston
Dasa ported and polished head
+1 intake valves, +2 exhaust valves
Stage 2 hotcam
Hd springs
43.5 fcr carb
Dasa ring and filter, oem intake tube
Dasa pipe
Running 91 pump gas
Thanks in advance!
I would say on our Dyno here in Tucson AZ elevation of roughly 2400ft if it was running perfect 12's AFR I would guess probably be about 45 or 48 ish. It's always hard to say exactly. Also you could run it on another dyno and that dyno could say 39hp ours might say 43 or something to that affect. Air temps also make a difference. We see more HP on bikes we tune in the winter time vs in the summer when it's 100+ degrees in the shop where out dyno is located.
1 - 4 of 4 Posts
