1 - 16 of 16 Posts
Just wondering if someone could estimate how much HP I will be making:
2005 TRX450R
HMF Full Sport Exhaust
HRC Kit, minus the cam
Curtis Sparks Air Filter
13 Tooth Front Sprocket
Discussion Starter #4
I was thinking around 42 also, but I thought stock it was 38. Now after researching more for the stock HP for a 2005 TRX450R I have seen statements that range the HP from 32-38? Anyone know what the stock HP is for sure? thanks
My 07 was 39 with a slip on exhaust uni air filter and jetted
stock 04/05 was 37hp and stock 06+ was 42hp. with the HRC kit and full exhaust you could have 42-45hp tops, the stock piston is a slug holding back a few hp. add a cp or je 12-1 piston and it will be around 45-47hp
with the hrc header green wire mod slip on and hrc cam I made 47 on the dyno. Thats running no lid.
Keep er pegged
^ great resons above that support the fact that each dyno is diffrent and there is alot of factors involed in the results.
very true
Yep did an 08 today with hc2, hrc header w/motoworks slip on, k/n no lid and 42.5 fcr and after tuning it made 44hp 30tq on my dyno
high 30s
2005 TRX450R
I have an 04 Trx450r.
mods:
500cc big bore
+3mm stroker crank
Hod rod
CP 13:1 piston
Kibble white black diamond stainless valves
Hot Cam stage 3
Full pro circuit t4 exhaust system
Uni air filter/closed box
& jetted properly running on 110 turbo blue.
can anyone estimate my HP?
1 - 16 of 16 Posts
