1 - 6 of 6 Posts
Hey Im a newbie to quads so be easy!
I just bought an 05 450r from my girlfriends brother but he doesn,t remember if he put a jet kit on. How can i tell if it does and what are some other upgrades I can do? It currently has an exhaust system with headers i believe its an fmf power bomb, supposably a jetkit, and I am not sure if it has a filter I have to check as well. I f there is nop filter can I modify the stock air box? How good are the HRC KITS or should I just opt for a cam and keep what I have on it if there is already a jet kit?
your bike wont have a removable leak jet....
and if she runs good..... just add a cam... and you should be good to go....
if she runs poorly.... you can always add an HRC jet kit if needed.....
the fmf exhausts comes with the jets needed for the exhaust so yea it probably does have a jet kit in it wont know for sure unless you check the jets themselves to see what size they are
Discussion Starter #4
if she runs poorly.... you can always add an HRC jet kit if needed.....[/b]
I was told by another person who replied that the fmf exhaust system comes with jets. So if I did add a cam i it shouldn't have to adjust anything? What cam is good for bottom end power?
If it is jetted correctly now.....adding a cam will probably not alter the jetting much.... but changing your intake system will.....
a VERY good cam for the 05 is an HCII......jmho....
YamaWho?
a VERY good cam for the 05 is an HCII......jmho....[/b]
yea id say a very high percentage of users on this site run the HCII... including me! :thumbup:
1 - 6 of 6 Posts
