Mine does it to. (Stock 2008) I have heard that a cam will make this problem go away. I am installing a hrc kit with in the next month. Hope this helps you out.
Ryan
Mine does it to. (Stock 2008) I have heard that a cam will make this problem go away. I am installing a hrc kit with in the next month. Hope this helps you out.i have an 07 450er...chm pipe, esr intake and dynojet kit..always stumbles if u blap the throttle...alls i know is im runnin a 55 leak...im pullin the carb apart tomorrow so i will see what other jets r in it...does anybody have this problem? its done it even when it was bone stock[/b]
i willl second that,i installed the r&d accellorator pump with adj. leak jet and it made everthing so much easier to adj. also the fuel customs intake takes away bog and adds hp.i got 3.5hp from mine,(on the dyno)R&D adjustable leak jet is the answer.. easy t o adjust after any mods[/b]
