1 - 4 of 4 Posts
I’ve look around and couldn’t find any post for this issue maybe not even the actual cause idk , I just bought a 2005 Honda trx 450R from this dude he said it needed carb cleaning that it has sat cleaned carb and still can’t get it to start, starts puttering and backfiring a little bit when trying to start and give gas at same time noticed the fuel ratio screw was tight then noticed there’s a broken hose but can’t find out where it goes to could anybody tell me where it goes to and tell me if that’s the reason it’s not starting I work on cars but not quads just now starting to get into quads so sorry if I’m a little noobish on the quad parts and stuff
Discussion Starter · #2 ·
Don’t believe it can’t be a vent line or something like that because soon as your turn screw gas comes out of it
That is not the fuel, that is the fuel drain screw for the fuel bowl, when loosened it opens up and fuel drain out the hose you have circle. Or if the fuel bowl overflows, fuel will come out that hose as well. Neither has anything to do with it running properly As long as the drain screw is close.
1 - 4 of 4 Posts
