1 - 4 of 4 Posts
2014 trx450er
Hi I have a 2008 Honda trx450er and I can’t get the cam chain on it seems way to tight tensioner is out and still can’t get it..
I had this problem putting a new chain on my rebuild, make sure it isn't stuck on the bottom end then loosen the cam bolts and tilt the cam a little toward the chain side. Have the cam gear in the chain and try and wiggle it on. It should go on, just take your time with it.
Discussion Starter · #4 ·
It goes on just seems way to tight
1 - 4 of 4 Posts
