1 - 4 of 4 Posts
I just went and picked up a 2007 Honda trx450er
The guy said that the battery was bad so I went home and put it on my trickle charger and my charger said that the battery was already at full charge. But the lights don't work and the neutral light barley comes on. But as soon as I jump it it starts right up. So I left it idle for at least 15 min and and turned the key off and directly back in thinking that should have created a little but if a charge but it was the same scenario. Looking for thoughts on what to do.
Bad ground somewhere check all ground wires and connections, make sure ground from battery is good to the motor.
1 - 4 of 4 Posts
