save up for some portwork or go for the quadforce grafix.
That makes to much sense...think of it this way
if you dont replace the chain and sprockets and throw the chain you very well might break a case. then you will be saving for a long time.
then the exhaust.
always do the maintence first[/b]
Let me get this straight, you have a big bore, higher compression piston and a Hot cam stage 2 with stock exhaust???K well I got about 150 to spend. I got a few options but need help.
I got a 480 big bore with 12:5:1 and a HCII. Now with my extra cash should I buy a
Barnet dirt racer clutch kit = 140
Dyna ignition = 110
Save up for an exhaust?
Old fenders to cut up = 120
Tires for the rear Im at 50% tread left.
chain and sprocket set? I am running worn down stock with this extra power build.
Save up for suspention and a arms?
save for port and polish?
Any other options are welcome.
Pleas let me know whats the smartest thing to do..
thanks[/b]
