1 - 1 of 1 Posts
First off I’ve searched this and all forums I can find nothing😣. I’m reassembling my 06 450 after I had the frame powder coated. I’ve got to the point everything is connected, grounds are all good as I ground the powder off. I am getting some power to various parts. The neutral light turns on when the key is on or off and when the orange switch is in the off position only. I jumped the coil and the starter fires. Other than that I have no power anywhere else. I checked the fuse, also I get power when I touch the positive lead of my tester to the positive terminal to the battery and the negative lead to any bare metal on the bike. Also the battery is new and at 13 volts. Any suggestions?
1 - 1 of 1 Posts
