Hello, I just wanted to share on how I installed grease fittings on stock a arms and what parts I used. I'll have pictures posted below for a visual aid. When I originally had the idea of putting grease fittings on my an arms I searched this forum and most people said it was "impossible" or to just spend the $250 on the sealed bearings. However I wanted to be different and try something new. Automatically I ran into problems. The main issue was getting the little clips that hold the Oem bearings in which I ended up just melting and breaking them with an ascetalyne torch. Once those are out you should have an issue if you, the reader also would like to do this.
for the bushings, I used one of those Amazon bushing kits which actually turned out great and everything was tight. It says they are meant for a 400ex but they will work on 450 an arms. You will also have to drill through the metal tube using an 1/8 inch bit to make sure grease gets to the bolt
Next i had to figure out if the grease fitting would clear the frame, which they will depending on your placement. On the front part of the an arm they will have to go underneath because they will hit your frame if they are on top, unless you noch out the frame which I did not want to. You can see where I placed the fitting in the picture below
Everything clears the frame so the fitting sheering off isn't an issue. As far as the fitting towards the back of the quad you can place it on top of the a arm because there is a notch in the frame from the factory which is convenient
again everything will clear the frame.
There is no squeak in these bushing and I do recommend them for someone who is looking to do a project like this. If you have any questions/comments/concerns please ask, and if you would like to see pictures of the upper an arms with grease fittings let me know and I will post some. Thanks for reading!
