Can I ground out the green wire on my 05 and still plug the harness back in to make it run full time ? Thanks
Thats the best way to do it in my opinion. Im going to do it to my quad. I know its easy but I may have questions while i do it. Stand by please.That's the way I wired mine, and works perfect!
I did that but instead of switch I put a plug in the wire so I can have it off when needed( haven’t needed to yet ) although a switch is a good idea. I have mine running full time when riding.Could you leave the wire on thermostat and slice one off that wire to a ground with a switch? That way you have both? A switch and a thermostat? Thermostat will kick on automatically when hot, if switch is off? Is that possible?
If you splice at the thermostat signal, the rocker switch will be FAN ON continuous on one side and THERMO SIGNAL will be the other. So yes the fan will always run or the thermostat will trigger it.Could you leave the wire on thermostat and slice one off that wire to a ground with a switch? That way you have both? A switch and a thermostat? Thermostat will kick on automatically when hot, if switch is off? Is that possible?
Right. So if my switch is off (fan not running)?If you splice at the thermostat signal, the rocker switch will be FAN ON continuous on one side and THERMO SIGNAL will be the other. So yes the fan will always run or the thermostat will trigger it.
