If you buy a petcock rebuild kit they usually come with the bolts, and new rubber seal. But yours might need some epoxy too. You should be able to install the kit, instead of buying a new tank.
You can by insert nuts to match the bolts and opoxy them in. Then screw petcock in. Is what I meant by epoxyIf you buy a petcock rebuild kit they usually come with the bolts, and new rubber seal. But yours might need some epoxy too. You should be able to install the kit, instead of buying a new tank.
Have you tried JB weld? Ive heard of guys using a drill to spin the nut in the hole to heat up the plastic then fill it with jb weld. Supposedly super tight. try that (after its fully cured). If not. Might as well get the IMS tank 🤷🏻♂️. But I do see the frustration.Yeah I’ve tried the epoxy thing. What you see is my attempt. When it began to get tight the nuts twisted out. Super annoying as you can imagine
insert nuts? I tried JB welding some nuts in. the remnants are what's visible in the holes where the nuts would beYou can by insert nuts to match the bolts and epoxy them in. Then screw petcock in. Is what I meant by epoxy
Something like this, If you epoxy (JB weld) in the insert nut flush, you can use the screws to tighten down the petcock. You would just have to make sure the nut is the right size and thread for the screws.insert nuts? I tried JB welding some nuts in. the remnants are what's visible in the holes where the nuts would be
Maybe its just easier to get a new tank 😂, if you can spend the money.You would epoxy in the hex shaped nut, and use the petcock screws instead of small screw in pic. Im sure Home Depot will have the right size nuts for stock petcock screw. 🤷🏻♂️ Jmo
Let us know how you make out, iether way. I am curious to see if nut inserts work and how long. Remember use a drill to spin the nut and heat up plastic, then fill it with JB weld. If you take that route. But the right way to fix it is get a new tank. Good luck.👍yeah i'm leaning towards the replacement tank idea. I may still try the thread inserts. But yeah, it's looking like a replacement tank is in its future...
Looks clean too. Nice work 👏. Hopefully it lasts.Update. No leaking in 24 hours.
I used permatex 2 slow drying non hardening gasket to seal up the o-ring on the filter. And that seems to have done the trick.
This is with just water in the tank - but apparently it is fuel resistant. So, I think I fixed it. View attachment 153979
