Forsale: 2007 Complete Engine w/Carb
Description: 450er Motor from Oil bolt to Valve Cover. Comes with all mounts attached with bolts. Also comes with factory carb jetted for an exhaust. I have the factory jets to go with it. I have left all cables and bolts attached so it is a quick and easy install. It even has the recall done for the one way starter clutch. I have pictures that I will post up later as well as a video of the motor running. This motor has low hours. I'd say anywhere from 20-30.
Price: $1600 shipped with carb, wiring harness, cables, mounts, bolts, sprocket, shifter, etc. Pull it out the box and install. I may even throw in some other left over parts if you need them. Just ask.
