What does reverse threaded mean? Sorry..not very mechanically inclined
thats right...except you dont have to loosen the chain first....Just switch sprockets, and then tighten the chain because it will be to loose afterwords.Originally posted by joe1l@Mar 16 2004, 09:02 PM
The sprocket is held on by a normal bolt, it is not a reverse threaded bolt! Just loosen the carier on the swingarm so that you loosen the chain, then take off the sprocket gaurd and the case saver, then loosen the nut to the sprocket, and pull it out with the chain still on, and switch sprockets. Realy easy, takes about 5-10 minutes to do.
Im just running stock wheels and tires for now....It does give more down low, but it dont seem to be near as low as a stock 400ex...its still pretty tall first gear, even with the 13 tooth...I like it both ways, it depends on where I ride and with whom i ride with.Originally posted by aces high33@Mar 18 2004, 11:31 PM
O.K. Thought that might have been too much but I am a rook. What size tires do you run Lude. Lot's more bottom w/out adding to the rear? I will throw the 13t on tomorrow (fri.) and see how it feels. Tips from the Lude!Thanks buddy. I really appreciate all the input as I try to get this thing dialed in.
Mike
