21 - 21 of 21 Posts
Do you know if this key saver fits with the TM design works chain guide
As @Bullvine rider!! alluded to, there are several chain guide pieces. There is the front case saver that bolts to the engine, the front or lower chain roller mounted the the frame, the rear chain slider that is on the front of the swingarm, and a chain guide out back on the swingarm if you decide to run one. The case saver bolts to the engine, and if you already have a case saver, such as the T.M. Design one, then this won’t work with that, they are the same type of part, however the UPP is a much better design and works better. If you want to run a sprocket cover up front like the stock plastic one, or carbon fiber, you can run one with the UPP case saver, you’ll just need longer bolts. But it’s not necessary to run o cover, it’s more just for looks.
21 - 21 of 21 Posts
