So I have finished the first phase of my build. It is an 07 electric start I bought in stock form. It had set for quite a while was suppose to be low hour. When I bought this thing it was barely running, it would kill the battery before it would start, the tires were rotten, when I got home it still had the stock foam filter on it and it was so rotten it disintegrated in my hands, fuel leaked from the carb and tank. In other words it was in sore shape.
The goal of this quad is for a desert/dune build. I have no name for my quad yet, all my quads have a name but they have to earn it and I don't have the the seat time on it yet.
So what did I do:
AFTER
Phase 2 will be a complete suspension redo.
I plan on using the OEM shocks have them revalved, 2 inch extensions and dual rate spring up front, and in the rear a new link, revalve and single rate spring in the rear. I also plan on going with a full Ricochet skid plate set. Hopefully this will all be finished before my big St Anthony's trip in June. 🤞
If you are interested in seeing what I did you can follow this build on my youtube channel "Torque your nuts Offroading" I have a playlist dedicated to this build. Thanks to the entire forum for helping with this build, this is a great community compared to the toxicity of FB!
So what did I do:
- Full service, every fluid changed out for fresh new fluid, adjusted the valves, chain and set sag on the suspension
- Relaced the tank with a enlarged IMS tank
- Fixed the Carb and rejetted to 165 main 45 pilot and a 55 leak jet (I adjusted the timing of the shot 1/2 turn out)
- Modded the air box with 1 inch holes, new uni dual foam filter and a outwears around the filter itself.
- Ripped out the old exhaust and replaced it with a monster big bore exhaust system
- Installed new Odor Advents 23 inch fronts and 22 inch rear.
- Installed a Hot Cams Stage 2 camshaft
- Replace the battery with a lightweight lithium battery (new battery also has more AH than the stock one and 5 less pounds!)
AFTER
