1 - 4 of 4 Posts
Was out on a ride a while back...WET!!!!....when I brought it home 2 clean it up the filter (UNI) passed some dirt/water. Also, the oil got water too....i mean a pretty good drink of it. My questions are these..... What component in the top end the the dirt is gonna hurt. I'm guessin rings cause it seems like it's usin' oil now...that and i'm sure it scores the cylinder wall too which won't help with sealing. Seems too like its lost some power. Secondly....how in the world did so much water get in the bottom end?? The oil was pretty milky. The top end is "sealed" so to speak, from the bottom end. Breather hose? And if it got sucked through the filter that much water would surely stall it....
if you run in high water you can get the water in your cases.. this is not uncommon. you have case vents and so forth that the water can seep in. I have run into it a couple times doing repair work. you can fill the cases up with deisel and it will help flush the water out.
1 - 4 of 4 Posts
