Went for a ride today. Hit the starter button and started up normal. Rode for 15 min or so then stopped and shut it off. Went to turn it back on and nothing no lights, neutral or tail light. So I push started it and it fired up.
Got back to the garage and tested the battery voltage with a digital multimeter and it has 0 volts. I just got this quad but I am pretty sure the guy said that he just recently got this battery last spring. How can you tell if it is the battery that is bad or it is something else?
I have a manual so i was doing some testing. While running I checked the voltage across the battery(the charging voltage) and had 1 volt. Even with the battery dead should this be 13-15.5 volts? In the manual it says to make sure you have a good battery so I don't think it is accurate unless you do?
Also I disconnected the handlebar switch and put a digital multimeter across the green and black wire in the harness which in the manual is the Generating voltage inspection and also got about 1 volt.
is there a a way to test the charging system with a dead battery in it?
