1 - 4 of 4 Posts
Ok Im trying to replace my bars but need to unplug the ignition switch and temp light. I popped the hood open and tried to unplug the ignition switch plug but I cant seem to figure it out. The is one main tab and two little tabs. Is there a trick I need to know about like squeezing it a certain way? I have already started to mangle it with a couple screwdrivers and stopped to ask before I continued with the wire cutters :wacko:
Just changed my bars. Forget the two side tabs on the outside. There is a single tab on the inside that you pull up on at the same time as pulling on the plug. It took me a few cuss words to figure it out.
Yeah I finally got it too, I was pushing that clip down (against the plug) instead of away from it. Once I got it I felt like cussing myself. Leave it to Honda to make it TOO easy to figure out, lol.
1 - 4 of 4 Posts
