they heat this carb so it will run better in cold weather....it has one becasue this carb has a throttle position sensor....if you are in a warm climate, simply re-route the radiator hoses around the carb, this mod helps keep the carb cooler. No it will not heat the gas up and make your engine run hotter, what this does is allow the air thats comming into the engine to be cooler....they heat the carb so that the air coming into it is warmer,,,,,its simply to make it run smoother and more reliable...however having the air cooler gives you more power....the cooler the air comming in, the more power you get....I am into Import racing, and they have this mod on all the honda cars.....simply bypass the coolant to the intake manifold....However you do not want to do this if you ever ride in cold weather...it will make it run like poop.....hope this helps.
