1 - 2 of 2 Posts
Would this cause an issue for the cylinder? There is one on each side from the piston. Other than this, the cylinder looks pretty good and still has cross hatching.
Water Eye Liquid Blue Fluid
2004 TRX450R
I don't know which cylinder picture your looking at, what cross hatching? but the picture above looks like the rings were not spaced correctly and possibly wrong in the order. How many rings came out 2 or 3..... If you think its ok, Hone and re-ring the piston correctly if you can get the flatness out of the cylinder walls. I dont think you'll have much meat left after that much honing.
1 - 2 of 2 Posts
