1 - 8 of 8 Posts
just what the title says....what is the best way to cut plastics?? what should i use to cut them with?? thanks for the help!
this is how i did it:
first remove plastics to cut, then use masking tape to mark the lines you want, tape the inside ( the part you want to keep) so the jigsaw wont scratch it up.
next use a jigsaw to cut down close to final lines,
then i used aa mini grinder to finish the lines.
after that i used so 200 grit sand paper to smooth everything out.
and last i used a torch to give the edges that factory rounded look. just dont hold it in one place for tooo long.
hope this helps you get the look you were after.
seth
Discussion Starter #4
I used a dremel with a cut off wheel and it cuts it like butter. I did mask it off with tape like ^^he^^ said as well.[/b]
thanks! the dremel tool was the route that i was thinking, what kind of bit would you recomend?? a steel burr bit, or an abrasive one??
use some type of cutting wheel, the abrasive/grinding wheels will more or less melt the plastic and then it will be much harder to keep your cuts going in a straight line.
U used a regular black cutting wheel with a dremel less mess than a jigsaw but still ave to be careful, use tape like the rest said it makes for better accuracy.
1 - 8 of 8 Posts
