1 - 10 of 10 Posts
· Registered
I was wondering if anybody has put the crf carb on the trx. I need some help getting this thing dialed in. I am currently running the stock exhaust with a open airbox lid. I have a 172 main, 45 pilot, and the air screw is 2.5 turns out. Any help is greatly appreciated.
· Registered
You might PM Rico'450R, he has a FCR carb on his quad.
· Registered
I think you will have to jet up on your main....172 is a bit to small.
· Registered
Brian22, I'm running a 160 main and a I think 42 low on it
I'm going home for lunch today and I will get the spec's for the carb and the cam.
I'm running a 2 stage Hotcam, CRF39 carb, and a slip-on pipe! I will post about 1pm pacific time.
TRX450R spec's
Stage 2 Hotcam
Intake
Lift: 10.1mm
Lobe Center: 109.75
Duration @ 1mm: 248
Valve Lash: .15mm
Exhaust
Lift: 8.7mm
Lobe Center: 105.5
Duration @ 1mm: 268.5
Valve Lash: .28mm
FCR39mm Keihin Carb with Hotstart and TPS
Main Jet - 160
Slow Jet - 45
Needle - OCEMR#3
Mixture Screw - 1
Main air jet - 200
Slow air jet - 100
I also ran a Pro Circiut pipe Titanium slip-on With no air box lid and a UNI filter!!
There it is, enjoy and I hope your bike runs as well as mine!!!!! good luck!!!!
Honda Forever!!!
On the Hotcam box it said CRF450 02-04, so I think it has the same spec's as the CFR cam!
'And yes the 2 stage cam gives you that seat of the pants feel!!! with no doubt!!!
Like I said 3rd gear is unreal!!!!!!!!!!!!
· Registered
are you running no air box lid?
· Registered
Brian22 jetting FCR40 and FCR39 are going to give you 2 different results.
Joe
· Registered
Discussion Starter · #7 ·
Im currently running without the airbox lid. It seems to run fine on top, but with it sitting there idling it sounds as if it has a miss. I am just wondering if my pilot is a little bit to big. If I just barely blipe the throttle and let up it starts to run rough. I have a 42 pilot and I am going to try that. Thanks for all the help.
1 - 10 of 10 Posts
