Have any of you guys experimented with porting a passage from the crankcase into the oil saperater in the case to reduce the pressure in the crankcase!!! I was thinking of doing this but I cant decide if there needs to be pressure in the crankcase the help push the oil out!!!!
i never thought about opening it up, but.. on a gsxr1100 we installed a vacuum to the case to reduce the oil mist and gained a little over 3hp so it might help. im not sure about needing the pressure or not.
i would think that you want a negitave pressure on the crank case........the piston would not have to push the air under the piston out as it is pushed down by the explosion of the a/f mixture during combustion.....in a vaccume, the piston will travel down with less resistance.........so it should turn up faster.......if you notice your stock air box has the vents plummed in so it will draw air out of the crank case......but how do you do that with an esr intake or other types of aftermarket intakes?.......just a thought.......bryan
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Honda TRX 450R
