crank removal and installation
5.3K views 3 replies 4 participants last post by  hybridpower
The crankshaft on the TRX came out easier then any other crank I've ever had to do. I didn't need a case tool or anything. If you tap on the crank just be careful of the threads or splines (depends on the side).
If you've had other cases apart, this will be easy.
