Crank brg retainers
1139 Views 3 Replies 3 Participants Last post by  06erdj450
Crank brg retainers breaking on rhs case
I have had this happen and found a retainer and bigger 8mm bolt to use, but still have had this break
Anyone else on this forum had these issues and fixes
First happened to me on 07 20hrs
Now on a 08 5hrs
What is wrong with these engines
1 - 4 of 4 Posts
Call up Toby at Moto-Xperts 765.230.0514
He used to have a page on his website talking about how the retainers were set from the factory in the wrong position. (cocked off to one side) Causing a piece to snap off of the retainer and wreaking havoc in the engine. I dont know if he has a fix for this or not, but on the old page I remember he shows you how to position them flush to the bearing and not have them cause any problems.
If you were really worried about them snapping, look into some kind of metal treatment for them. Cryo comes to mind right now, but I am sure there are a lot more options.
Just talked to Toby. Very smart guy. Basically when the factory torques down those retainer bolts to 12 ft lbs they just torque them down and leave them and a lot of times while torquing those bolts down, the tab gets cocked to one side making uneven contact with the bearing creating many low-hour engine failures. Adding any performance engine parts increases this failure rate due to the extra force being exerted on the crankshaft and that force being transfered into the bearings/bearing retainers/cases and finally breaking off the corner off of an incorrectly set bearing retainer tab.
The CORRECT way to torque down these bolts is to hold the retainer FLUSH with the bearing (using a screw driver or pliers) while torquing to 12 ft lbs. (with red lock tite)
When I took my engine apart my retainers were sideways. It had nothing to do with my engine blowing but I fixed it when I put it back together.
One thing to be careful of if you put bigger bolts in is to make sure they are no longer. I heard someone did this and the crank ended up hitting the tip of the bolt and destroyed the engine.
1 - 4 of 4 Posts
