1 - 5 of 5 Posts
Alright guys, I have read through the whole crank bearing thread (now at 9 pages long) and was wondering if there is a preventative? I just bought an 04 a couple of weeks ago. I just changed the oil and did not notice any shavings on the filter (although I did not know I was to look for them.) I have no clue what is done to the motor (maybe it already had a failure and has been replace? I don't know)
All in all, is there a way to "fix" this before it becomes a problem?
The best thing you can do is to make sure you're using a good oil and change it often. Check the filter every time for shavings.
Discussion Starter #3
The best thing you can do is to make sure you're using a good oil and change it often. Check the filter every time for shavings.[/b]
I guess, how do I make sure not to get any. If I detect some, then what do I do?
Oregon Coast Powersports
like bueller said, change the oil often with good oil.
if you find shavings its time to replace the crank/ rod assembly. you can also have the stocker rebuilt but its not worth it in my opinion.
a new hot rod rod is like $125 plus labor to install. ive been told its about $60 for the labor which i think is pretty cheap.
you can pick up an oem crank for $210ish or a hot rod crank for $225ish.
if you are really worried about it just pop off the oil filter cover before each ride and inspect the filter.
you dont have to change the oil everytime obviously. i typically change the oil after every 2 rides which can range from 12-20 hours.
Discussion Starter #5
Thanks for the help guys! I'll keep an eye out..
1 - 5 of 5 Posts
