I have had to replace mine, actually just replaced the bearing again. They are not hard to do, just need a tool to take the nut loose on the balancer loose. The bearing I have had go out more often is the water pump bearing, put about 4 of them in.
Thanks!I have had to replace mine, actually just replaced the bearing again. They are not hard to do, just need a tool to take the nut loose on the balancer loose. The bearing I have had go out more often is the water pump bearing, put about 4 of them in.[/b]
