1 - 4 of 4 Posts
I have a clicking noise that sounds like its coming from the rear of the swing arm ,when I put it on a stand it doesnt do this , could it be the bearings? Has anyone else had this problem ? I have only had the quad 6 mos. any help would be appreciated.
Thanx,
Mike
                          Thanx,
                                  Mike
<div align="right">index.php?act=findpost&pid=19241
[/quote]
This sounds like your berring I would get that checked on.
                          Thanx,
                                  Mike
[/quote]
I had the same problem with my bike, it was the axle nut had come loose and there wasn't enough tension on the carrier bearings. I loosened the jam nut(which wasn't very tight) then re tensioned the main(thicker) nut. Remember these nuts are reverse threads.
1 - 4 of 4 Posts
