1 - 1 of 1 Posts
HI,
I just bought a used 2001 Yamaha warrior 350. I realized now that the chain is very loose, even though the chain and sprockets were just replaced by the previous owner. I read the manual and adjust the chain according to how it says. Loosen the upper and lower hub nuts, and then tighten or loosen the adjustment screws according to how you want to adjust tension. However, I did all that and the chain will not get tighter or looser. I stripped one of the chain adjusters not realizing that I was not movi the carrier at all. How do I fix this issue, and get my chain to adjust? I have read things online that maybe I need to remove the carrier, but that seems complex and would be doing that in my driveway. Anything else that may be wrong and cause the chain to not adjust? I should also mention the the wheels pivot side to aide when the nuts are loosened, but I suppose the carrier isn't moving.
Thanks
1 - 1 of 1 Posts
