1 - 9 of 9 Posts
· Registered
hey guys so I have a 04 trx450r and it ran great then I got a lexx slip on exhaust and a stage 2 hotcam. put the exhaust on and ran great then I installed the hotcam and now when I start it and run it smoke comes out of my bottom end breather hose and after a couple minutes oil starts oozing out of the same hose. Any ideas?
· Registered
06 HRC cam new piston rings crank shaft cam chain sparks full exhaust uni filter many more bolt ons!
So you went with the lexx anyways 👍. Do you like the power with the pipe and cam?
· Registered
· Registered
yeah it definitely changed a lot and gave it a lot more power. sounds pretty good too. I went with the lexx so I could tune it View attachment 153562
You need some new tires broski , looks like a tire nascar runs 😆 , when you pull the trigger on tires check out obor advents, good tires and wont kill the wallet. Not the cheapest , but definitely worth price to quality ratio. 🤙
1 - 9 of 9 Posts
