1 - 5 of 5 Posts
Prolly a stupid question since every track setup is different. The track around here is fairly tight, lots of big jumps; mostly 3rd-4th gear wide open... curious to what the average gearing you guys/gals are using. I'm 180lbs, running stock gearing on my '06. Will be installing an HRC kit as soon as it arrives so I'll have more snap outta the corners.. just curious if most gear up, gear down, or leave the gearing alone.
Cale Downen runs 13/36 on his 07 and thats what I just switched to. It was too low geared for me with stock gearing.
Discussion Starter #3
Cale Downen runs 13/36 on his 07 and thats what I just switched to. It was too low geared for me with stock gearing.[/b]
wonder if I should try a tooth down up front for starters...
depends on how much power you have to turn the gears, i run 14 38 on my 07 that makes 57hp 36ft but on smaller tracks i switch to a 13 to get better drive.
1 - 5 of 5 Posts
