1 - 4 of 4 Posts
i want to know if the hrc or sparks cam is better when running a chm pipe. i also have a 13 tooth sprocket in front and i am going down 2 teeth in the rear so it is alittle shorter than stock. what would be the best cam with this gearing.
and also how much top speed will u lose when running those gears.
Discussion Starter · #2 ·
ok thanks but i am going down two so i dont sacrifice ground clearance and i also think the 13 tooth is alittle to short so going down two with the 13 is going to be between 13 and 14. One tooth in the front is like 4 in the back
1 tooth in front is 3 teeth in back, not four.
Discussion Starter · #4 ·
yeah i know its not much of a difference but it will save me some time away from the clutch without it ready to stall cus when i am following my friends they go slow as he11 out in trails
1 - 4 of 4 Posts
