Depends on how bad the valve is bent!!! May cause a misfire, backfire, poping...
Only way to no for sure is to do a leakdown test!!!!
Gah, didnt hear any misfire, or backfires as it was idleing after i heard the knock, but didnt rev or ride it. And i dont have a compressor and a leakdown tester nor does anyone I know. Do dealerships do it? How much would it costDepends on how bad the valve is bent!!! May cause a misfire, backfire, poping...
Only way to no for sure is to do a leakdown test!!!![/b]
A dealer or qualified shop can do it... cost....mmmmm..... 1-2 hr @ shop rate!!!!Gah, didnt hear any misfire, or backfires as it was idleing after i heard the knock, but didnt rev or ride it. And i dont have a compressor and a leakdown tester nor does anyone I know. Do dealerships do it? How much would it costDepends on how bad the valve is bent!!! May cause a misfire, backfire, poping...
Just ran my bike thru all gears, feels and sounds good! I doubt i bent a valveI would think your valve clearance would be lose if you bent a valve(s)
Reason being if it were bent, it would'nt retract all the way thus suddenly having extra valve lash...[/b]
I can see that!!! Good point!!!I would think your valve clearance would be lose if you bent a valve(s)
Sounds good.....Just ran my bike thru all gears, feels and sounds good! I doubt i bent a valve[/b]
The only sound I've heard from bending valves is a rapid clacking noise..... like a automatic gun!!!!
Dont cross the black cat on halloween!!!!LOLI can see that!!! Good point!!!I would think your valve clearance would be lose if you bent a valve(s)
Thank you. I never had a bent valve to date (knocking on wood right now...lol)
