1 - 20 of 21 Posts
here's a run of a bike i ported the head on last week..........i don't know what all is in it because i did not build the motor....but here's what i do know
stage-1 HC
hmf full pipe
48 before 53 after
Discussion Starter #2
i was not there for the testing or i would have made sure the a/f was better
and i told him to dump that cam but he said it works great for his riding>>>trails
i still think the stage-2 would be ALOT better..........but as they say the customer is always right
between 6 and 6.5 rpm.. what is that flat spot in the curve? is that how the hot cam stage 1 looks?? because i have stage 2 and mine was a real smooth broad curve
between 6 and 6.5 rpm.. what is that flat spot in the curve? is that how the hot cam stage 1 looks?? because i have stage 2 and mine was a real smooth broad curve[/b]
i've seen some explain it as intake harmonics. some bikes dip in that rpm range. could be something else???
buck, nice improvement.
what year is it??????????
Discussion Starter #5
its a 04
i don't know what that dip is,but alot have had them.........and most people think its the intake
48hp out of an unported 04 is pretty strong to begin with. especially with a hc1.
48hp out of an unported 04 is pretty strong to begin with. especially with a hc1.[/b]
Ha-ha! That's how buck makes 60hp on his own build!
What a joke!
Discussion Starter #9
well, being that i don't know what
piston
carb
fuel
intake
is no it you can't really say
Discussion Starter #10
only think i was wanting to see was how much he gained from what i did.....and i'd say he got his $100 worth
What a joke!
my bike pulled 43hp fully modded except 4 my porting on the same dyno
so are you saying that the porting on your quad made the extra 17hp?
and if so, why didnt you give him the same level porting you did for yourself?
dont you always claim to be able to reproduce your head? dont you also claim to give your best to everybody?
Discussion Starter #12
QUOTE(scrapper450r @ Jul 22 2008, 09:50 PM) index.php?act=findpost&pid=534384
<div class='quotemain'>48hp out of an unported 04 is pretty strong to begin with. especially with a hc1.[/b]
What a joke!
[/b][/quote]
[/b][/quote]
you see you only say something when you THINK your bashing me!!
after adding
DASA PIPE
BIGGER CARB
BETTER INTAKE
MY PORTING
BIGGER CAM
BETTER FUEL
I PULLED 17 MORE
STOP TRYING TO BASH ME....IT ONLY MAKES YOU LOOK STUPID
AND NOW ITS EVEN MORE THAN 17 :unworthy:
HAVE A GOOD DAY
QUOTE(mwsartain @ Jul 23 2008, 07:50 AM) index.php?act=findpost&pid=534470
What a joke!
[/b][/quote]
after adding
DASA PIPE
BIGGER CARB
BETTER INTAKE
MY PORTING
BIGGER CAM
BETTER FUEL
I PULLED 17 MORE
HAVE A GOOD DAY
[/b][/quote]i only said something because you were the one that said "fully modded except 4 my porting" the only reason i can think of for that statement was to make everyone think that your porting gave you the extra 17hp.
maybe you should have said, i gained 16.9hp from a dasa exhaust, big cam, U4 fuel, bored fcr carb, better intake, dyna cdi, and hundreds of dollars and hours dyno testing.
What a joke!
[/b][/quote]
after adding
DASA PIPE
BIGGER CARB
BETTER INTAKE
MY PORTING
BIGGER CAM
BETTER FUEL
I PULLED 17 MORE
HAVE A GOOD DAY
[/b][/quote]
I guess I'm confused also, what do you mean by fully modded?
VENOM PIPE?
42MM CARB?
STOCK INTAKE?
NO PORTING?
HOT CAMS STAGE TWO?
C-12?
Break it down for us.
Discussion Starter #16
it had these when i got 43hp
14.1 baldwin piston
stage-2 H/C
ROSSIER full pipe
no air box with stock tube
K/N filter
thats pretty well modded to me
I think we should give buck the same level of respect as everyone else gets on this site only because he started this thread to show results.
I do not like the way you act around here at all Buck, but i do think that the comments should stay outa his thread.
JMO-Kip
What a joke!
ha-ha, what a PRICK!!, sorry but if all you are going to do is bash, just shut up and don't post!!
[/b][/quote]
How asked you! Mind your own business little boy.
[/b][/quote]
i think you ment who.
check me out, the worlds worst speller givein someone else chit.
i wouldnt worry about it mark, the guy has been here for less then a year, he has no idea what the whole story is.
1 - 20 of 21 Posts
