oh yeah im also running a stage 2 hotcam
I have an 05 with stage 2 HC, stock bore, ESR intake and full FMF and run a 50 pilot and 190 main.I have a 05 kicker ive just re-built thanks to crank bearing failure!! im running a sparks exhaust, pro flow kit, and just added a new 14.5 to 1 Dasa piston with dasa crf ignition mod and also a new FCR carb with adapter, the bike will start with the choke on and run good but when you turn the choke off the bike will start to back fire, and die. Whats do i need to do with the Jetting?? Carb is new with a 45 pilot and a 175 main[/b]
