I use a compreesion tester and set mine at about 65 psi on my 06er
Gah dont have a compression tester, dont have a compressor actually. How do you set it up with clearances? It was loose around .25 should I tighten it or loosen it? And my bike does seem to run hotter for some reason, just changed oil and tranny oil. My friends yfz runs hotter than mine so it doesnt bother me THAT much, and the oil light doesnt come on but my fan comes on alot fasterthe cam change isnt going to make the bike run hotter. the best method to set the decompressor is to use a compression gauge. i believe the e start bikes should be set around 65psi. the tighter the clearance the lower the cranking pressure will be and vice versa.[/b]
